apex
Does anyone know of anyone uk based who can make/supply ss inserts like you get in snowboards/wakeboards? thanks.
TimothyClaypole said:This type?
No unfortunately not. I'm unable to post links/pics yet but what i'm after is effectively what you'd get if you welded an m6 nut onto a m4 pennywasher (what i've been doing so far). Basically an m6 thread (blind), with a flange/base so it won't get pulled up/out of the board and got to be ss so it doesn't rust. I've found plenty in US n China but you have to order 1000's and shippings ridiculous.
apex":o7kr0eks said:Yeh kind of although i've no need for the prongs. The pic below shows what i'm after.
The problem is that most of them seem to have the hole go straight through where as i need it to be blind at the base so that the screw cannot be over tightened and burst through the underside of the board as it's only glass n epoxy. ideal height would be 6mm. Seems to be such as hard style of fastener to find in the uk.
bugbear":k5yy46b5 said:apex":k5yy46b5 said:Yeh kind of although i've no need for the prongs. The pic below shows what i'm after.
I see. I assumed the plate/washer was on the far side of the board to provide positive resistance to being pulled through, so "bursting" isn't a problem, since the hole goes through the board anyway.
How are the things you have in mind secured to the board - is it just glue ?
BugBear
TimothyClaypole":3uxw19us said:
tinytim1458":21z5v9l1 said:did you go to this company in the UK
http://www.fastenerdata.co.uk/products/weld.html
or these
http://www.comdir.co.uk/Products.aspx/x ... lessSteel/
both have exact what you want.
Shrubby":1khi9hqc said:The snowboard inserts are sold by ski repair brands
Wintersteiger - the agent is Skiequipmentuk
Maislinger-snoli and kunzmann sks - the agent is kandie-imports
search for 'snowboard multi-inserts'
Matt
