Squaring the end of Contiplas panels
Knot Competent
25 Apr 2004
Bristol
OK guys and gals, I need some wisdom from those who have gone before..
An imminent project requires me to hack a couple of sheets of the dread Contiplas into pieces, and make the ends dead square. As both my table saw and circular saw will leave poor edges, due to a need for new blades, my expectation is that the final squaring and trimming can be achieved with a router and jig. Can anyone direct me to a picture or plan on the Net for such a jig? I need to cut panels up to 24" wide, and would like the jig to ensure dead-square ends.
Any help would be really appreciated.
Regards, John
thewoodgnome
2 Jun 2004
cambs
Hi John and hello all
As a total novice, I would score the cut line with a sharp knife to eliminate chipping of the surface before cutting and then finish with a guide clamp and router.
cheers
Paul
CHJ
31 Dec 2004
Cotswolds UK
Regards, John
Have a look on your local market stalls for a cheap roofing joist square.
Possibly Aluminium maybe steel 450mm X 300mm or there abouts.
(usually £2-£3) and use it to align a Straight Edge guide for the router.
Not a long term tool to pass on to the next generation but good enough (and square enough for what you require) to last the year and then throw away.
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi John
Both of the tips are good ones, but do you have a jigsaw that will give you a good cut?
If so, score the cut line and then use the jigsaw. To give you a good edge finish it with a router. Could you use some of the contiplas to give you a straight edge?
Hi Paul
Good tip and welcome to UKW.
Neil
Knot Competent
25 Apr 2004
Bristol
Thanks Chas, that's a good idea. I'll go for that, to set up an accurate jig. But I can't picture the jig in my mind, which is why I need a nudge in the right direction as to how to go about making the jig. Just running the router along a clamped piece of Contiboard won't enable easy multiple use, whereas a router-powered sort of shooting board will. Just can't see how at the moment, which is the reason for this query.
Welcome, Paul. Hope you learn as much as I'm doing, which increases the pleasure of achievement.
And Neil, I've never got to grips with a jigsaw. Two reasons - only ever had a really cheap one, and poor technique. So cutting on the table saw and final trimming with the router has to be the way for me.
So, any pictures or plans out there?
Regards, John
Chris Knight
14 Jan 2004
SE London - NW Kent
John,
It's pretty easy to make something like this
You can use say 6 or 9mm MDF about 8 inches wide, a piece of straight wood for the longitudinal fence. Use your regular router/bit combination to trim the edges then all you have to do is line up the edge of the MDF with your cut line on work you wish to trim with the same router bit combo.
Just make sure the fence underneath is at right angles to the fence on the top!
Also make sure you mark the router base and have the same position turned to the fence whenever in use. Not all router bases are symmetrical and many are not concentric with the bit.
Knot Competent
25 Apr 2004
Bristol
Yep, seen them Chas. I'll try a couple back-to-back on a flat surface to make sure they're square before I buy.
Thanks for your trouble, John
