PeterSk
So after the excitement of the new lathe thread, here's a few photos of the first three real pieces I've turned on it.
First is this in sycamore
Mostly an attempt to turn something sensible out of a small starting blank. As you can see I found out that I drilled the hole for the screw chuck a little bit too deeply, so when I was making one of many correcting passes on the base I found the bottom of the hole, so I decided to turn it into a feature and finish the piece off anyway. The wife suggested that it might make a good lid for something.
Second is this in oak
This was inspired by a comment from miles about not going thin on bought blanks, so was an attempt to go very thin from the off on a bought blank.
Too thin in fact! :lol: I went through it when I was working from the top side, and it only stopped short of taking a ring off the edge as the dovetail wasn't cut accurately enough to present a parallel work face when tightened in my chuck.
I wouldn't have been happy with this anyway, I've made it too high waisted so that all the curve happens too far up the piece, I did have it right at one point but a slightly over-eager cut left a chisel mark somewhere that was impossible to get out without redefining the entire curve.
Finally is this, a deeper bowl style in ash. Excuse the naff photos, my camera is having trouble focusing on the piece.
This turned into an experiment in chisel sharpening really, I ended up trying a lot of different grind angles on my bowl gouge, and I think I started to get the hang of working a shape inside of a deeper bowl like this. Haven't cracked it yet by any means, but the only marks left on the inside are the ones that I couldn't be bothered to stand there sanding out.
Everything's been finished with Chestnut cellulose sanding sealer followed by a coat of microcrystalline wax. Once I've got my cole jaws set up, I'll take the ash bowl and re-wax it using the lathe to buff it up.
