I need to get on with finishing this canopy (started over a year ago), so I can get on with repairing the door frame, painting the door, plastering the hall and so on...
My idea is to get a solid polycarbonate sheet and screw it on - it doesn't need to connect to the brickwork/ render as it's just to keep the rain off the door area. I wanted to get 10 mm sheet but that's expensive, so thought 4 or 5 mm would do - the total dimensions of the area to be covered are 1200 x 2100 mm.
Would that work (ie, will there be enough support with the structure I have) and if so, how much oversize do the holes for the screws need to be to allow for expansion (this side of the house gets sunshine only in the evenings)? And is drilling into polycarbonate pretty easy (compared to acrylic, which apparently can split)?
I don't know if that's enough info to go on, but I'd appreciate any thoughts before I go spending a couple of hundred on the sheet and messing it up.
Chris
Chris
