sploo
Somewhat extinguished member
I keep hearing that so called cabinet saws (induction motor, cast iron table, heavy) are better than site saws; partly because the "accuracy of cut is better" - but, I never see any facts or details to back that up.
I've been looking at the Bosch GTS 10 XC site saw for my small workshop, but it's occurred to me that for larger cuts (i.e. an 8x4' sheet) I’d still probably be better just using a handheld circular saw outside. As such, the portable aspect becomes less important.
I'm now considering the Axminster TS-200 and TS-250M, as well as the AW10BSB2 or even the AW12BSB2.
I understand the difference between a universal and induction motor - though to be honest the advantage of induction does seem to be mostly if you get a really big one, and run it for hours a day. As a hobbyist, I expect I'd be doing occasional short start-stop runs, so I don't think induction is a clear cut advantage for me.
So, in the case of "better" is it simply the mass of the cabinet saw tables, the quality of the machining, the quality of the fences, reduced vibration in the motor and spindle? If I were to go for a budget option (e.g. the TS-200) do those advantages still hold true?
The AW10BSB2 and TS-250M have almost identical cutting capacities, so I assume the huge difference in weight (184kg vs 80kg) is down to the former's much larger table, and perhaps a better built motor (including the ~50% power increase)?
Any input from those who have used various machines greatly appreciated!
