Last weekend I started using my SIP p/t, and after surface planing an edge on some oak for a table top I noticed that they were slightly banana shaped. Time to read the instructions! Those supplied were poor so downloaded the Perform P/T instructions from the Axminster site (recommended here - thank you).
Placing an alloy straight edge across the the infeed and out feed tables I noticed that the front edge of the infeed table was about 0.5mm below the edge of the out feed table when the straight edge was flat on the out feed table and just touching the back edge of the infeed table. I have adjusted the grub screws on the outfeed table so that they are completely withdrawn into the outfeed table casting, but still the tables aren't exactly parallel, and there is no more adjustment on the grub screws.
Anyone any idea how I can set up the tables so they are parallel? And yes - I have checked that my straight edge is straight
by reversing it, and I get the same result both ways.
