Hi folks,
My ts4010 wont stay running unless i hold down the start button, I took the switch apart and found the electromagnetic coil had some burn marks on it and the wires had snapped. Does this indicate any deeper problem with the motor or does the switch just need replacing?
I had the same problem with it before and was advised to bypass the thermal cut out which fixed it.
The bypass is still inplace (black wire).
Doesn't look like I can post the pictures, maybe PM?
Any ideas much appreciated
