Sharpening lathe tools
Nippychippy
27 Feb 2013
Dundee/ Dublin
Hi everyone again I have been watch a good few vids on YouTube about sharpening lathe tools I have the Keith rowley book it gives you a bit of detail about sharpening and i made the jig in the book but I can't find images of what the chisels sound look like I find that there not as good as they could be ill try get some images of my chisels a lot of the vids people are using finger nail shape gouges :?
Looking forward to the held
Robert
Being relatively new to the game I had issues sharpening to begin with. These are my findings, although probably not 100% correct.
One of these is the baby. You can get them here in the UK, this was just the first site I found.
Check the angles against the jig to make sure the jig angle is spot on. I made a jig very like the Cap'n Eddie jig which is pretty much foolproof.
Also make sure the sparks are coming over the top of the tool. If they are not, the edge is not touching the wheel properly.
The first two are the long ones
I am also a beginner but I would say
1,2 ,4 &7 are bowl gouges.
3 is a skew
5 & 6 are spindle gouges.
8 & 9 scraper
10 & 11 are parting tool
"Ducks for cover expecting to be shot down in flames by someone with better knowledge"
1,2 are bowl gouges.
3 is a skew
4,5 , 6 & 7 are spindle gouges. (the shoulders on pic 4 look like it has been over ground as they are concave. it should be either straight or slightly convex i believe)
8 & 9 scraper
There are numerous sharpening systems on the market. Grinder jigs that clamp to a bench under your grinder seem to be popular. be careful when grinding not to let the edge of the tool get too hot or it will ruin the tempering. Another system that is popular is the wet stone system which negates the heat problem. Google Tormek and you will get an idea of what I mean (other wet stone systems are available)
Ye I seen the tomek system it's a bit to much money at the moment the is a guy on eBay sell nice
Home made tru grind jigs so ill try the cheap one first but with the gouges what sound they look like
Hi NC
I don't know what the Rowney jig looks like but from your photos it looks as if you are sharpening the gouges as if they were pencils. By that I mean that you are rotating them about their long axis.
Look at this page. The first video is what I mean. What you should be doing is shown in the second video.
http://aroundthewoods.com/sharpening01.html
When you are finished they should look like http://www.woodcentral.com/newforum/grinds.shtml
Bill
Thanks for posting that Bill. The second link shows perfectly the convex shoulders I mentioned.
Nippy, for bowl and spindle gouges its easiest to use a purpose made jig which has like a dog leg. For a normal bench grinder something like this set will be a great help
http://www.ebay.co.uk/itm/wood-lathe-sh ... 20d66467d3
I was lucky enough to get a Jet wet stone system (very similar to the tormek) with all the jigs for wood turning tools on Ebay for £100 so they are out there.
http://www.youtube.com/watch?v=tUzTI6ayMW4 this shows a comparison between Jet and Tormek
That second link is perfect form me it gives me an idea of what it should look like
I just sharpened them as I got so when I get the jig hopefully it be a better grind thanks for all the help folks
Hi, I had major problems sharpening chisels when I first started and tried various methods with limited success .
I eventually bit the bullet and forked out and got the Tormek system and associated jigs. I have not looked back since, producing good sharp edges of the correct profile is just so simple. I know that the Tormek systems are very pricy but the investment has been well worth while.
