RogerS
Hi chaps. Recently moved into a new place that has it's own private water supply with all the gubbins in the cellar.
There is a pump that is switched on with a pressure differential switch. There is also an expansion tank connected into the water pump at this point. Inside this tank there is a diaphragm with air pumped in on one side to a certain pressure.
So I'm told that it works like this. When you turn on a tap in the house, the water pressure in the pipes drops and that triggers the switch which turns on the pump (let's call this the Low Pressure setting) . When you turn the tap off, the water pressure builds up until it reaches another setting on the differential switch (let's call it the High Pressure setting).
The diaphragm/expansion tank arrangement is to stop water hammers and dampen down the abrupt cut-off when the pump stops.
So...what settings does one set for Low and High Pressure typically and what do you pressure the expansion tank to?
Any ideas ?
TIA
Any ideas ?
TIA
