Graham Orm
You May have seen my previous thread asking for feedback on Scheppach tools. https://www.ukworkshop.co.uk/forums/anyone-had-much-experience-with-scheppach-tools-t71541.html
Since then I have bought this http://www.angliatoolcentre.co.uk/s...e-saw-240v-with-1-4m-guide-rail-pid40065.html I've been using the saw all week on 3/4 ply, so it's had a good test.
A Scheppach CS55 track/plunge saw with 165mm blade. Beware if you are thinking of buying one they come with various sized blades the P145 has a 145mm blade. There is also a P155.
On the other thread 'Nippychippy' made a couple of observations as he already has one and 'hates using it'.
His three main points were: The cord is too short, the return spring that lifts the saw back up from the cut position is too strong, & the saw wobbles on the track meaning that it's difficult to get a 90 degree cut.
I agree fully with the cord length. NC said he stripped the saw and attached a new cord. I intend to cut the plug off and extend the cord by soldering the wires and then shrink tube insulating the joint with a healthy wrap of insulation tape over that.
The wobble is not an issue for me. I have checked numerous cuts and have have not found one that is anything but 90 deg.
The return spring is too strong, but is easily fixed. It sits on a shoe at the bottom and can be easily removed. I cut off about 5 coils in 3 stages. This now makes holding the saw down in the cut straightforward.
The accuracy of the thing is excellent. The track sticks down like glue and makes cutting sheet so much quicker and easier than with a conventional circular saw and home made guide.
I would recommend this tool. It's significantly cheaper than the competition and I can't see how spending the extra would give a better result. I'll be using it for work, kitchen fitting so if I find a major glitch rest assured I'll be back to comment.
Rating 8 out of 10. But for the spring and cable it would have been 10 on useage to date.
