Hi,
a while ago I acquired a big-ish old backsaw (14" blade, 13tpi, crosscut), and the time came today to give it a sharpen and set. I've not had a problem previously setting a saw (no expert, but I've done it half-a-dozen times now), but this time for the first time I managed to break a couple of teeth - not by trying to set them in the wrong direction, I hasten to add!
Before resharpening, I tried to guestimate the existing set by gently applying the set to the tooth at the extreme end of the blade. I was using a Somax (the one for fine teeth, 12-20tpi) and tried it on the No 8 setting, and the tooth broke; I assumed, the setting was too coarse, and so used a No10 setting for the real thing after sharpening. All fine until about 1/3 along on the first pass a tooth broke, and further on another (even though by then I was going very softly).
Now all the other saws I've sharpened have been relatively modern (max 20/25 years old, I'd guess). This one is stamped Taylor Brothers, which would make it about 100 years old, if I understand correctly. So my question is : could age be the reason? Does the steel get more brittle with age? Or did they perhaps use a more brittle steel in the first place to make saws in those days?
Thanks for any enlightenment
