Shivers
- Joined
- 29 Dec 2006
- Messages
- 243
- Reaction score
- 0
I have a nice number of table saw & mitre saw blades i'd like to get the arbor hole size changed over to euro sizes.If they were not such nice blades i wouldn't bother.
4 amana 72 tooth 12"(1"arbor hole),
5 systimatic(various teeth count)10"(five 8th's arbor hole)
1 delta atb(60 tooth) 10"(5 8th's arbor hole)
systimatic fine dado set(5 8th's arbor hole)
Is it feasible to get these machined from the existing arbor hole size over to a metric euro equivalent ?.
Theres quite an outlay of money in these & it's a shame at the moment to see them sitting idle.
One thing i remember about the dewalt mitre saw i had was that there is a flange that could be turned around allowing either a 1" or 5-8th's blade to be fitted,---do the euro models also do this ?.if so should i purchase a euro model & order a spare flange from america .(or are there other mitre saws that also do this already available here in euro).
The dewalts are ok but i'd prefere something more hardwearing,so i'm trying to avoid buying another.
Apart from the dado set,i'm also considering having all the above converted to 30mm arbor & having a bushing reducer made at 16mm.
are these sensible thoughts or should i just forget about it?.
Theres probably £700-800 worth of blades here if i had to buy then again.
regards.
regards.
