Router template guid bushes
Eyesaw
22 May 2019
essex
Hello,
I seem to be having trouble purchasing touter guid template bushes to fit my Makita 700c palm router.
After ordering a silverline set then receiving a message from seller that there was a problem with the batch made.
Not sure where to go.
Any suggestions please.
Eyesaw
22 May 2019
essex
Hello Mikejhn,
Have you had experince with using guid bushes on a makita 700c palm router ?
Im not sure the which is the smallest size bush available to fit the palm router and i don't like doing returns.
I'd like to rout as close to my template ad posible.
Thank you for your help
nev
21 Jan 2011
The green and wetter end of the M4.
I maybe (probably am) way off the mark here but I always thought there were specific size bushes for specific templates. If making your own templates then surely you just work from the bush/ router bit size you have or wish to use.
Trend recommend a certain clearance between bit and bush so the bush size changes depending on bit size used.
I don't know if the Trend ones fit the Makita without an adaptor plate but there a fifty to choose from from trend.
https://www.trenddirectuk.com/trend-rou ... ide-bushes
Eyesaw
22 May 2019
essex
Thank you for hour replies.
I think i'll just go for a top bearing straight cutter bit.
sunnybob
wysiwyg
11 Oct 2014
cyprus
If youre routing by hand then a bottom bearing is easier to use.
Eyesaw
22 May 2019
essex
Thank you.
My template which i like to see is ontop of workpeice therefor i feel that a top bearing will suit me better. I will make several cuts using different size top bearing bits.
Lets see how it goes.
MikeJhn
Grunkel
2 Sep 2014
Kent mostly and France the rest
Eyesaw":11u9f07m said:
Hello Mikejhn,
I don't have a Makita, I have the Katsu clone and fitting it with the base plate and bushes from the Triton offering.
Eyesaw
22 May 2019
essex
Just an update.
I managed to use a top end bearing 1/2 x1/2 x1/4 shank to cut around a internal template i made with 3/8 ply.
Using the same router blade i stepped down 4 times untill the 3/4 mdf was cut.
im happy with the result.
I'll gladly post a pic when i learn how.
