Router table question
Chippygeoff
19 Sep 2011
Nr. Swansea
I am quite new to routing but used them quite a lot when I was on the tools a few years back, mainly hand held for hinges, rebates etc. I have just bought from Axminster one of their UJK compact router tables, its exactly what I want. To cut a long story short several parts were missing and after several phone calls some of the missing parts will be here tomorrow while others are going to take a little longer. They are ordering a new fence assemble. What surprised me was that there was no mention on the instructions and I could not see any on the diagram. I am on about spacers. the rods that go behind the outfeed fence when using the router table as a jointer. I should be able to adjust the outfeed side of the fence by 2-3mm I would have thought so that the fence supports the wood as it passes the cutter. I hope I haveexplained this okay. The fence is a beautiful piece of kit and there is provision for spacers behind the MDF sub fence. Any ideas anyone if Axy fail to come up with something.
The 'traditional' American method is a piece of Formica stuck to the outfeed fence with double-sided tape. You can also get plastic packers in 1mm increments from Screwfix, Toolstation and the rest. I expect they're quite approximate, but I use them on the router table and they work well (but mine has a threaded adjustor for the two sides of the fence).
Otherwise pieces of cornflakes packet? It's not a precise art after all, and if you're intending to do what I did - use it as a planer with a tall 1/2" cutter - you can't take deep passes anyway and still hope to get a decent finish. The shallower the better really.
Aren't the cardboard sleeves for Rizla papers supposed to be 10 thou (papers themselves being 1 thou) or have I remembered that wrong? :)
E.
