Router Lift for amateurs
Niki
18 May 2006
Poland
Good day
Most of the router tables are actually a cabinet.
I would like to share with you an idea for router lift.
Because I don't use cabinet as router table, I made a mock-up so, a little bit of imagination please...
Regards
niki
Code:
[img]http://i158.photobucket.com/albums/t104/nanikami/Router%20lift%20amateurs/RL001mm.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/Router%20lift%20amateurs/RL002.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/Router%20lift%20amateurs/RL003.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/Router%20lift%20amateurs/RL004.jpg[/img]
[img]http://i158.photobucket.com/albums/t104/nanikami/Router%20lift%20amateurs/RL005.jpg[/img]
Another great idea Niki.
The only thing one has to be aware of with all these home-made lifter ideas is that the air intake is not blocked. Many routers need proper airflow around the motor for cooling, and it's easy to make the pressure pad so large that the airflow is impeded.
Yours looks nice and small in the photo, but I just thought I'd mention it in case anyone else makes it up.
Steve
Thank you for the remark, I forgot to mention it
I have the Hitachi M8
I removed the backplate and as you can see the center part over the motor/rotor is blocked. Same on the back cover.
I glued a metal plate of 20mm diameter, that will not effect the motor cooling.
But to be sure, please check your router
niki
