Roubo-workbench in Southern Yellow pine with leg vice
gasman
14 Nov 2006
Near Oxford
I have taken the liberty of starting again with this thread as the old thread http://www.ukworkshop.co.uk/forums/26-cubic-feet-of-southern-yellow-pine-t70334.html had got a bit waylaid
So, the plan so far is to make a slab 95 x 650 x 2400 of southern yellow pine for the top - then legs which are 110 x 145 x 900 morticed into it - quite a lot like Chris Schwartz's Roubo bench in his infamous book
So far, I had cut all the SYP up into 15 '4x2s' 2400 long, cut the legs and rails etc separately, bought (and then sent back shortly after) the Veritas twin screw vice and the Veritas inset vice. Instead of these I will have the Veritas tail vice on the right hand side and a Maguire wooden leg vice on the front left.
Then I laminated the legs
Glued up the boards for the top in 4's
Then when they were dry, planed one side of each block by hand with a QS no 6 / Record no7 and then thicknessed them down to 98mm thick. The 4th (front) group of 3 boards will be shorter due to the tail vice going on the right hand side
AFter thicknessing I put them all on my current bench to see how they look:
And here is the tail vice put roughly in place:
This weekend should get the slab complete - then to start cutting leg mortices. So enjoying this job!
Mark
    147.6 KB
    150 KB
    152.5 KB
    173.2 KB
Thanks Mick
The top is absolutely massive - glued up the third big piece onto the other two yesterday - I can no longer lift it!
Then started thinking about the legs - so first, after scoring a line round all 4 sides of the bottom of each leg, I planed a 45 degree bevel of a few mm, then with a small Veritas BU plane with a PMV3 blade (I couldn't resist buying one to see what all the fuss was about - it really does hold an edge for ages) - planed the bottom flat -
then sealed all 4 with tung oil
Finally last night I cut the tenons on the other ends of the legs.
I set up with sliding table on the tablesaw with a stop, cut both sides of the cheeks of the tenon on the table saw set at 30mm height and then cut the vertical sides of the cheeks on the bandsaw - easy peasy with a lovely tuffsaw blade
No huge c**kups so far - plenty of time for that still! The bench top will take quite a bit of planing - amazing how despite it looking really flat before glue-up - it is now out by the odd mm here and there.
Next are the mortice / tenon joints of the legs / rails - these will be drawbored
Mark
    162 KB
    174.3 KB
    201.6 KB
    189.4 KB
Looking forward to see more of this.
Though it may save a bit of time, could you not have a word with a friendly local wood company to see if they could flatten your bench through a machine in one pass for you?
Though a nice big LN jointer would help, or....the router method that was touted on here a while ago.
Thanks for the comments
No skills - I bought a gallon of TB1 and a gallon of TB3 from Axi earlier this year at a ridiculous discount - so far I have used about a third of a gallon with laminating the top and legs
the_g_ster - if the top did not weigh 120 kg (estimated) and there was anyone near who could do that (oh and also carry it 100 yards to the road from my shed) it would be an option - but so far yesterday I flattened the bottom within 1mm all over - and I will leave the top until the whole thing is assembled. I actually rather like flattening it - it is a good workout!
I got some M&T joints cut yesterday for the framework. Here's an end rail - again as for the legs cut to depth on the table saw then the cheek cut away on the bandsaw
Here's the leg being morticed using a 25mm forster bit on my morticer
Then the corner are just tidied up with a mortice chisel before a test fit:
And then a test fit when both ends are finished
Today's instalment starts after 10am when I can start making a noise in the shed!
Also I have finally decided on 2 vices - the Maguire Pinless Leg Vice http://www.theenglishwoodworker.com...page=product_info&cPath=65_71&products_id=264 which will be £245 I think, plus the Veritas tail vice both of which I am looking forward to making immensely.
Thanks for looking
Mark
    170.3 KB
    173 KB
    161.5 KB
    161.5 KB
    163.4 KB
James over at Deep In Wood at Besselsleigh has a wide belt sander, and has been willing to put bench tops through it for me in the past.
Thanks for that - didn't realise he was so close - but it is really the problem of getting it out of the shed, down the garden and onto a van which will be my biggest trouble - I am happy to flatten it in the shed on site...
So yesterday I finished morticing all the legs and the bottom of the table to receive the legs:
Here's a leg marked up for the long rail mortice
I had to swivel the morticer round - clamping the back down onto the MFT3 as the legs are 100 x 140 in cross section so too big to go under the morticer in its normal configuration
After drilling out on the morticer:
Another dry test-fit...
It took a couple of hours to do the other 3 and get the whole frame dry-fitted
The front long rail is slightly diffrent - it is thicker - 100mm vs 87 for the others - to allow me to cut a bevelled profile which the sliding deadman will slide on. There is a corresponding profile on the bottom of the deadman and doing it this way means there is no groove for dust to catch on
Then onto the big mortices in the underside of the bench top. They are much bigger and needed quite a bit more chopping out. The depth is 70mm
Two done:
When they were all finished I dry-assembled the whole thing.
I need to sort out the drawboring next - have to decide if to use a contrasting wood or the same stuff
Thanks for looking
Mark
    175.7 KB
    194.5 KB
    154.5 KB
    101.8 KB
    163.1 KB
    135.5 KB
    215.3 KB
    172.8 KB
    146.3 KB
So onto the drawboring - I have never done this properly in the past - only put in a peg for reinforcement. Chris Schwartz is, as ever, very knowledgeable about it - so I decided on 3/8" size - found a couple of old screwdrivers with 8mm and 9.5mm shafts respectively and ground the blades off
The I have ordered a 3/8 veritas dowel cutter as I do have a dowel plate but it's metric
http://www.axminster.co.uk/veritas-veritas-dowel-cutters-prod819741/
I'm going to be sad when this is over - such a fun project
Thanks Mark
    156.3 KB
Quite good progress this weekend
Drawboring to start with...
So here's the first pair of legs with the short rail
Holes drilled carefully at right angles through both sides of the mortice
M&T joint reassembled
and the tenons marked with a lip and spur bit for where the hole should be - dissambled again:
The hole is then drilled 2mm closer to the cheek of the tenon (can't find the image sorry)
Meanwhile some spare SYP was cut down to 10mm square and the ends tapered with a knife
This was then mounted in a drill and put through the Veritas 3/8" dowel cutter
Then the dowels were cut to length and the ends tapered gently
I reassembled the joint and used my newly made drawbore pin to squeeze it together
Glued it all up and hammered the pins home
Then repeated this for the other pair of legs - and then did exactly the same for the M&T joints for the long rails - so the whole base is glued up and drawbore-pinned
Some of the pins rotate as you drive them home so I did not bother to try to align the grain - don't think it matters a jot
Finally for this bit, when the pins were all dry I flush-cut and cut them carefully with a sharp chisel
More of this later but can't upload anymore photos for now
Mark
    159.1 KB
    154.8 KB
    147.9 KB
    159.3 KB
    193.2 KB
    206 KB
    159.8 KB
    178.7 KB
    140.2 KB
    160 KB
More progress... the sliding deadman was next
I cut a piece 600 x 225 x 40 and planed it square all round
Drilled a series of alternating holes on both sides 75mm in from the sides on the drill press with a 3/4 inch forstner bit
Then cut them to shape on the bandsaw
ONe end had a simple tenon cut on one end to allow it to run in a rebate which I cut with a router on the underside of the table. The other end of the deadman was cut at 45 degrees on the table saw to produce this end which I tidied up with a shoulder plane and chisel. This will run on the top of the front long rail
Sanded the corners off and it was done:
Back to my frame - here is the base all glued up and drawbored:
It needed a very small bit of correction of the cheeks of the big tenons on the front 2 legs - but otherwise fitted well
Here's the rebate in the underside of the front of the top
And here is the first dry assembly of the whole bench - lighting not good sorry
I also cut some spare teak to 19mm square and ran it over a 3/8" roundover bit on all 4 sides to make these 3/4" dowels which will be the bench dogs
and using bullet catches I made the first 2 wooden dogs which fit in the deadman quite well
Mark
    182.8 KB
    166.4 KB
    179.7 KB
    190.7 KB
    194.2 KB
    156.9 KB
    153.2 KB
    133.5 KB
    171.1 KB
    125.9 KB
Progress is slow as I have been busy at work every day :(
However over the weekend, early mornings and occasional evenings I have been working on the tail vice - once I had got my head round the concept it is quite straightforward
Here's the base plate and the screw mounted - the plate needs to be exactly parallel to the top
Now the 2 plates which slide on the base plate are mounted here to see how they slide
Next I cut and planed all round 2 pieces of SYP 525x75x19mm which will be the 'core' of the tail vice. One of them has a recess routed out to take the upper plate. The thickness of my bench (95mm) means that the lower of the two plates will be below the bench
Then it was a question of completing the 'core' of the vice by glueing up a block at either end with the 2 longer pieces either sides. Here is the core of the vice complete with the upper and lower plates. They are fixed in place with a bolt which goes through holes drilled in the core
The distance between the 2 plates is obviously crucial as the base plate runs in the grooves between them. The book talks about putting shims if necessary - like cardboard to make the gap bigger but these seemed to be about right. It slides very smoothly with almost no play
Next I cut the hole in the far end block for the vice screw to run in - this is a 1 1/8" forstner bit running in the morticer
The base plate needed to be recessed so that there was no gap - so I did that carefully with a router and deepned the upper groove with a 1/2" chisel as well
The rest of the tail vice is fairly straightforward - it needs a top piece which will be coplanar with the bench - you can see the slot which the upper plate fits into
And finally for now the end piece which the mounting plate for the vice will screw into. The 1 1/8" hole is drilled here too and two holes for the screws that hold the mounting plate
Hope to get the tail vice all finished very soon but it is looking OK so far
Thanks for looking
Mark
    178.7 KB
    150.2 KB
    154.4 KB
    189.8 KB
    154 KB
    186.2 KB
    162.6 KB
    155 KB
    130 KB
Thanks Paul
More bits and pieces done this week
I cut some 600mm lengths of full thickness SYP in half, then ran them though the bandsaw in half to make 23mm thick boards - thicknessed them down to 21mm and then rejoined them with dominos and clamped up to make shelves for under the bench
These were tongue and grooved to form a big shelf under the bench - I will leave them to settle for a while then they need fixing
Meanwhile the tail vice continues to be fettled to make it run smoother. I had made the gap between the upper and lower guides a fraction too narrow so used some 1/16" balsa to shim it out a fraction and that worked much better- the balsa can be compressed by pressure from the two bolts squeezing the two guides together.
It now runs very smoothly and just needs planing into line with the top and side of the bench
Finally last night I thought about drawboring the top onto the base. I had decided to use 1/2" drawbore pins but first had to make the tool. SO I found some old 1/2" steel bars which I think were part of an old curtain rail
Ground it down using an old 40G belt sanding belt, then polished up to 400G
Finally found an old piece of olive to make a London pattern octagonal handle for it later today if I get home from work in time
cheers
Mark
    146.1 KB
    175.8 KB
    179.7 KB
    129.9 KB
    140.5 KB
    217.1 KB
    214.3 KB
    201.1 KB
Getting close now - almost time to demolish my old bench
Drilled some holes - alot of them and there's more to go.
I did it using a morticer with a 3/4" forster bit in it to do the first 2 inches or so
Then I used an augur bit in a hand held electric drill to finish the job
The holes are 80mm apart all the way along the table. There are 6 in the tail vice as well
The top and sides of the tail vice were made coplanar as well
And here's clamping some timber on top of the bench
FInally yesterday I cut and machined up the leg vice - waiting for the hardware to arrive from Richard Maguire which I think should be next weekend
    190.2 KB
    170.9 KB
    196.1 KB
    201.5 KB
    181.7 KB
Finished off the 1/2" drawbore pin
and drawbored the bench together - dry so I can take it apart if necessary
Demolished the old bench and moved this one into place - all it needs is the leg vice - hardware arriving next week I gather
I also liked the idea of the year carved on the leg vice - as in Chris Schwartz' book - so printed off some labels with the right size on, stuck them to the leg vice piece of wood
and then carefully carved out the initials using a v-groove chisel, a 1/2" straight and a couple of small curved gouges
So that's it until the hardware for the vice arrives
Happy days
Mark
    231 KB
    137.7 KB
    130.9 KB
    154.8 KB
