wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
Rather than a review, I thought I'd post some of my thoughts as and when I use it. Hopefully this will be more useful than "This is a great tool, I love it". ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So we started with a delivery.
As you can see I went feet first and got the whole lot. The Deluxe kit and then every single available accessory. I did it like this because I know I'd end up wanting it all and it was cheaper to buy it like this. Here is the full list of what I bought:
Obviously it's mainly for my turning tools. But I do flatworld stuff as well, so it will be useful for plan irons and chisels. I'm even looking into having some custom belts made up in higher grits for woodworking tools. I also have a small selection of carving tools that I've never had success sharpening.
The ProEdge does not have the selection of jigs that the Tormek has. Which is fine, but I think Sorby are missing a trick. It would be great to have a planer knife jig, scissors, kitchen knives, etc. Maybe they are planning this for the future.
So over the past few days I have been re-shaping all my tools so that they fit in with the presets on the ProEdge. You do not have to stick to their presets, the tool rest and fingernail profiler is fully adjustable.
The fingernail profiler is exactly the same as the Sorby Deluxe grinder jig I had before and I believe Tormek is the same too (invented by Tormek?).
On the other thread I mentioned a problem with the handles hitting the motor body. This is actually not what the problem was. What was happening was the actual body of the profiler was hitting the bed. You can see from this pic that there is a corner sanded off the jig.
oops. The confusion came in from the fact that the grind on my tools was\is much longer than the sorby jig allows. You might be able to get a better idea from this pic
I'm not sure if this is a restriction of the machine or something I am missing. You can see here that I have coloured the old bevel with a black marker.
The new grind off the ProEdge stops short of it on the larger tools. You also get more swing on the right side as the profiler body can pass over the side of the bed. The profile seems a bit 'pointy' to me. I need to look up the various recommended angles and profiles. I've read about it before but it's not sunk in.
I'm going to contact Sorby about this and see if it's just me doing something wrong. Would love to hear from owners if they have had this problem, just me?
I finished the gouges by just relieving the corner of each bevel to increase clearance.
Then on to the skews. This was striaght forward, but as I'd ground my skets with a convext bevel, it took a great deal of work to get them sorted. The benefit is that I can hone the edge right up to 240g and then a quick swipe on the ceramic stone. I used one of the skews on a pen I made today and the finish is easily equal to 400g
8) Here's the last skew about half way through re-shaping:
I have not been quenching them. Rich's comments in the other thread caused me to be wary of that. I'm not sure the best way to do it. At the moment I'm just leaving them to air cool. Is it right that a little 'blueing' on HSS is ok? Or is that Carbon Steel? :-k
Finished up today with a clear up and a sort out. All the jigs are stuck to the side of a cabinet next to the proedge with magnets. The belts are hun underneath the shelf that it's sitting on. This is all temporary. Once I've worked out how it all works and what I need where, I'll build a purpose built shelf with a drawer.
That's it for now. More thoughts and findings as they come.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![DSC_0997.JPG](https://proxy.imagearchive.com/d0c/d0ca69e34c81db45b0b665125bbd9615.jpg)
![DSC_1001.JPG](https://proxy.imagearchive.com/e3f/e3f17aa0084b54c851fd94efd6656d1f.jpg)
![DSC_1004.JPG](https://proxy.imagearchive.com/aa2/aa25f32a869006d605c27eba44c6233c.jpg)
![DSC_1026.JPG](https://proxy.imagearchive.com/5ee/5eed6da8a6cdbacb7acf627d48a03d7e.jpg)
![DSC_1025.JPG](https://proxy.imagearchive.com/487/487588d4ed9882243240cb682cd5cdce.jpg)
![DSC_1030.JPG](https://proxy.imagearchive.com/7d1/7d107bd7f73384b97d9ff6675da83954.jpg)
![DSC_1014.JPG](https://proxy.imagearchive.com/b6e/b6ebd3668967a3eb3e626a9affaa8650.jpg)
![DSC_1027.JPG](https://proxy.imagearchive.com/3f2/3f2b93037b02225ba6eac19091fed134.jpg)
![DSC_1037.JPG](https://proxy.imagearchive.com/e0a/e0ad1d376e2474b7580db758bdd93681.jpg)
