Item. F46-719 Fox 14" Professional Woodturning Lathe
Got mine from. Poolewood Machinery
Cost. £260 (Delivery included) Though cheaper now I believe.
Value for money. 8
Build quality. 7
Instruction manual. 4
Standard accessories 6
Overall score. 8
Score values:
10 - GET ONE NOW!
9 - Excellent. You will not be ddisappointed
8 - Very good. Start saving your money
7 - Good stuff. Worth getting, but a few problems
6 - Pretty good. With quite a few reservations
5 - Average. Could be better/could be worse
4 - Some redeeming features, but needs some work
3 - You might get something from this, but 'not a lot'
2 - Very poor. A huge ddisappointment
1 - Awful! Avoid this total disaster
The 'Blurb':
Aimed at the professional or serious semi-professional woodturner who is controlled by a budget, the F46-719 is an exceptional lathe at an affordable price. Manufactured throughout with gigantic proportions of cast iron, down to even a cast iron legstand, this machine weighs a substantial 134Kg - Giving YOU that so necessary stability required for professional turning, with the assurance that it won't dance its way around your workshop. A gutsy 1Hp quiet running induction motor continues the theme, providing powerful performance through a range of 12 turning speeds of 450RPM through to 2250RPM, which are steplessly adjustable via a well positioned control lever. This, coupled with a 14" (355mm) outboard bowl turning capacity, opens up an immensely satisfying vista of woodturning opportunity. Precision milling and finishing allow for a smooth and accurate operation. Industry standard components have been incorporated into the F46-719, to ensure compatibility with lathe accessories widely available, featuring a standard 1"x8tpi main drive spindle with integral morse No.2 taper and a morse No.2 tapered tailstock. The robust cast iron tail stock also benefits from a 3/8"(9.5mm) through hole for long hole boring in lamp production. Supplied as standard with cast iron legstand, four spur centre, revolving centre and a multi-positional tool rest. The headstock both rotates and slides along the bed, also includes a faceplate. Swivel headstock that can also slide along the bed.
My take:
Well, let me start at the beginning. Poolewood was by far the cheapest via Ebay. I did a fair bit of research, and decided to go with the Fox in the end, because of the cast iron stand.
The delivery of the lathe took longer than expected, because the first one sent got 'Lost in the post'. Hard to believe I know! :lol: The lathe was fairly easy to assemble. I actually did it on my own, but the manual (And I ) recommend you have assistance.
List of niggles:
The drive centre needed grinding as the "Bits what grip" did not engage very well.
The live centre came apart, exposing the bearing. I superglued it in place, and it is now OK.
One of the Cam locks was worn out. I am in correspondence with Hamiltons to resolve this.
The bottom of the tailstock had paint on it, making it difficult to slide on the bed.
Although the headstock revolves and has various locking points (well it did when I first tried it), they no longer work. Again, I am working with Hamiltons to resolve the problem.
The tailstock wheel isnt very smooth when you turn it.
The toolrest has an uneven surface, small nicks and bumps.
However, dont let that put you off. I have bolted (As advised) the lathe to a concrete floor, and I have had no vibrations whatsoever. The lathe is well made, it is a shame about the accessories.
The 'Blurb' claims a quiet running motor, well although I have nothing to compare it with, it sounds like a washing machine full of bricks at low speeds, but as the speed increases, it IS quiet running.
Overall, I am quite happy with my purchase, mainly because I feel for the price paid, I have a decent lathe, that should give me many hours of pleasure.
I would almost be tempted to recommend it, but I think I will play it safe, and not do so. :wink:
I will add to this review as time goes on. And also update my dealings with Hamiltons.
Value for money. 8
Build quality. 7
Overall score. 8
Score values:
10 - GET ONE NOW!
The 'Blurb':
My take:
List of niggles:
