cutting solutions
James
not sure how this has happened but I got an e-mail via the forum which I cant seem to reply to......sending address is "noreply@uk....."
Hopefully you will get this reply to the information you requested.
I do stock 315 blades with 2 tooth configurations with the pinhole dimensions you mentioned. 28 and 48 tooth available from stock.
The pinholes are CRUCIAL for the braking system on the machine. If you have the pegs on the flange on the machine you will need the holes in the blades.
Hope that helps.
Doug
Hope that helps.
Doug
