Replacing old window seals - aluminium double glazing.
RogerM
4 Mar 2006
Devon
My daughter has old aluminium double glazing. The seals are shot and the draughts coming through are horrendous. From the photos I've been sent, it looks like the outer layer is a fibrous brush type seal, and that someone has stuck some sticky back foam rubber seal over a slot where I presume a proper seal was once installed.
I shall be having a look myself in a couple of weeks, but it would be helpful to know beforehand what type of seal to use. Presumably a bubble seal of some sort compatible with the existing slot? Any ideas gratefully received.
Thanks Robin. That's a really helpful link. My daughter has sent off for the 10 Bubble Gasket Sample Pack. I'm sure there will be something from there that will fit, and we can order a supply of the right seal from that.
