thedonutman
I got a really cheap benchtop bandsaw off Ebay a while back and I managed to break the blade that came with it doing a rather tight corner on a guitar body.So I ordered another one from Dragon Saws and it broke at the weld the first time I used it. I contacted them and they were kind enough to give me another one for free. Installed that and I've been using it for a while.
I then noticed it doesn't cut as well as the one the saw came with even though it was brand new, same length, same width and same TPI. It still cut though so I didn't bother messing with it for fear of breaking it.
Fast forward a few months and very little use later, I've managed to break the second blade at the weld again - cutting 18mm MDF! I was trying to do a curve with it but it wasn't *that* tight.
I've still got both blades that have broken at the weld and they're pretty much brand new - anybody know where I can get them rewelded?
More importantly, how can I make sure the blade is installed and the saw set up properly to prevent unnecessary breakages in future? eg. What do I do with all the guides and how do I actually set blade tension? I got the impression that the blade was occasionally grinding against something in the saw itself when I used it.
Here's a picture of the bandsaw itself. It's got upper and lower guides and a tension adjuster that pulls the upper wheel towards the top.
