mooed":2bd3fkf5 said:Biggest gripe is that the doors are quite loose which affects the dust extraction, I have to often open the bottom door and manually push the build up sawdust so it gets sucked up but that's only after a hour of continuous use.
MikeJhn":o70cwwxd said:I think you will find that is a lack of extraction, my BS350 leaves nothing behind the doors, but I do have a 2000m3/hr extractor on it.
Mike
MikeJhn":2ceh7pwt said:Can't loose anything by clamping it closed and trying. Can't tell from the manual, but isn't the door held closed by a tougne, maybe this needs adjusting (bending) to close tighter?
Mike
