Record #778
Derek Cohen (Perth Oz)
2 Mar 2005
Perth, Australia
I recently acquired one of these rebate planes. I have been looking for one for a long while - the #778 is like hen's teeth in Oz. It is a good deal more solid than my Stanley #78, slightly longer and definitely heavier, and of course it has a much better fence.
What I want to know is if it comes with a depth gauge, as per the Stanley #78? Mine did not, although I can fit a Stanley to it as it has the screw hole and fence guide indent. All the pictures and adverts I have seen of a #778 show only the fence - never a depth stop.
If it does use one, has anyone here a spare Record depth stop for sale?
Regards from Perth
Derek
Derek,
As the photo shows, there is indeed a depth gauge. I got mine off Ebay for a song not to many moons ago, complete with depth gauge.
A few days ago, because I had been feeling guilty about owning a small boat anchor I never used (Alf and Slim - it's all your fault!) I used my Record 50 and then my 778 in a comparison test, cutting rebates (it was an early Sunday morning and I didn't want to incur neighbours wrath by turning on the router) and surprise surprise(!) the Record 50 made a nicer job of it. The tool felt more balanced and the thicker blade helped I think. I even went so far as to sharpen all the nickers and make some dados with the 50 but that is another story.
I know the newer Record #50c had thick blades, by my older #50 blades ain't exactly slabs.
I'm surprised at your 778 blades being thinner than #50 blades.
BugBear
BB
Thanks for the picture. I had not seen that one before.
The #778 blades are the same "thickness" (or should that read "thinness"?) as the Stanley #78. The #78 cuts well enough, but I did also wonder what the #778 would be like with a thicker blade? In fact, early today I was mulling over the possibility of making one myself. Does anyone make them?
Regards from Perth
Derek
BB
Derek
Just a thought, would it be possible to make a thicker blade by epoxying/welding a piece of steel onto the existing blade thus making a thicker laminated blade?
Stupid idea perhaps? :oops:
BB,
I just measured my 050's blades at .12 inches thick vs .08 inches for the 778 - so 50% thicker. Of course the 778 has a cap iron - the 050 doesn't.
Mudman, yes you could do that if you were so inclined, there is enough space in the mouth opening for a thicker blade so no mods to the plane would be needed.
My intuition (and failed memory) stand corrected; herewith some information gathered with the aid of severe case of the slope, and a Moore & Wright micrometer.
Code:
Woden W-78       0.085
UK Stanley #50   0.112
#043          0.122
#050          0.114
#405          0.115
SS #04       0.077
BugBear (who would have used an HTML table, but couldn't)
The LN #778 blade arrived and I have given it a quick spin.
It is well made, 1/8" thick and sharpens up very well ( it is sooo easy to cut a finger on these planes since the edge of the bevel projects from one side - DAMHIK!). A few practice shavings unfortunately do not say much, but it did do a very good job. Better than the Record blade?
The LN was an impulse purchase and made before I had even sharpened up the Record blade. I used the Record blade in the #778 for a project last weekend, and I must say that the LN is going to have to be damn good to improve on this!
Regards from Perth
Derek
