tigerhellmaker":mcezoluv said:
Philly":mcezoluv said:
A vote for the Trend T-11. Great router and very useful to be able to adjust the height through the table.
Philly
Next vote for T11.
Dewalt 625e is almost like T11 but T11 have nice lift system for table.
I think You can modify 625.
And another vote (T11) here!
I really like mine so far. The motor note doesn't change at all when planing 2 1/2" Idigbo (75mm worktop cutter). I love the through-table adjustment and well-behaved speed control. At anything other than top speed it's really quiet (for a 2kW brushed motor) too.
I haven't used it handheld yet. but expect good results.
In the router table I've only hit one tiny snag so far: My router plate has the usual set of 1/4" holes for a lead-on pin (for 'freehand' routing with a bearing-guided cutter). I don't actually like this idea much, and usually run the bearing close to a fence instead, for safety as much as anything, but it may get very occasional use.
The most useful hole for the pin is annoyingly close to where the height adjustor access hole had to be cut in the plate. I had mine drilled by an aircraft engineering firm locally, and we reduced the access hole's diameter to the barest minimum of 17 mm. It's actually 17.5mm, I think - (nearest drill size they had). But even that is perhaps too tight: 18mm would be ideal, and Trend spec. 20mm. The problem is that, although we avoided cutting into the lead-on pin hole (just!) part of the router's base casting now fouls the lead-on pin's hole underneath.
I think I'll have to 'adjust' it with a needle file. The pin needs its 'tenon' to be full depth for stability - I don't want a lump of steel coming loose and rolling into a cutter doing 20,000 RPM!
I thought long and hard about how to orientate the router under the table, and having the height adjuster front-right is the best compromise for me. it's a shame it's so close to the pin...
Otherwise I'm well pleased, especially with the micro height adjustment (easily better than 0.1mm). It's ideal for adjusting tenon faces really precisely with a surfacing cutter, and I've no doubt it will get loads of other uses in time.
If you do get a T11, and you want 1:1 drawings, I have PDFs for my plate (prints on A3 paper), and an Autocad DXF file. PM me if you want them.
