Re-Velcroing my sander
SeanJ
15 Oct 2011
herts
I user sanders all day long and have just recently bought a detail sander - a bosch type that cuts/saws as well as sands (Bosch PMF 180E Multicutte), anyway basically the triangle velcro sanding base melts if your not careful, leaving it knackered basically. It's a known problem as i'm reading other peoples cases, so instead of buying another baseplate, and another baseplate etc... I want re-velcro it myself and wondered if anyone had any tips or experience of doing the same? I think an expoxyglue to join the velcro to the base might be best as a rigid stick would be desireable, the glue on most velcro you'd buy would allow it to creep i'd reckon.
I need these sanders to use on staircases for detail sanding so i also need to come up with a maintenence plan for them instead of spending £'s a day on new bases!
Thanks. Sean
I can confirm the Fein multi master (which was the first of its kind) don't suffer from this (well mine at least). Maybe you could get hold and a Fein base. I'm told you can use the Bosch bits on the Fein so you must be able to the other way around, even if a little 'fitting' is required it maybe worth it.
Hi Sean
I had the same problem on a little green Bosch diy grade delta sander - the hooks had all worn away so it would not retain the looped sanding sheets.
I bought a few inches of self-adhesive velcro hook tape from my local independent DIY store, cut it up with scissors and stuck it on, poking holes through for the air flow. It's worked fine. I can't say how long it will last but it was cheap and quick to do.
I expect you can get the velcro from the big shed hobbycraft shops or eBay.
I have had it happen with my Fein, getting into corners and such. The solution is to turn the speed down and press less hard.
Jake":261aj4qo said:
Thanks for all the above, and yes it does seem logical not to go full speed in regard to heat build up, i use many sanders but the detail sander seems to heat up crazy quick!
If anyone else is intersted i tracked down a supplier of good width sheets that suites tool dimensions instead of the strips that are common.
http://www.abrasivesplus.com/buy/replac ... mm_156.htm
cheers. Sean
Thanks for the link.
Any ideas how to get the old velcro off? On my old B&D random orbit job, the velcro is stuck to a thin sheet of rubber like material which looks like it would rip if I apply too much effort pulling the velcro off. I thought about using a belt sander on it, suggestions ?
@ Rob, i'll let you know how I get on as i'm at the stage of removing a couple of velcro pads from my sanders along with the foam. I realised i just couldn't 'revelcro' as the foam will generally come with the knackered velcro too, so i've got some thin rubber/foam material that i'll ply between the hard base and my new velcro. Sounds like a lot of fuss but i'm hacked off how easy they melt, and as a commercial woodfinisher i need to have bunch of these spare for a few tools i've got. Just pondering wether a hard setting or flexible glue would be best suited to the job??
Starting to think it's easier just to buy a new platter, not very expensive for mine but I hate throwing out something that could be easily refurbished.
