Rail to stile ratio
Highwayman
18 Jan 2006
Stockport
Hi long long time lurker here with what should be an easy question
Is there a ratio for rails and stiles ?
Im building some wardrobe doors aprox 6 ft tall and cant seem to get the proportions right in my head for rail/stile
Paul
I suggest that your first step should be to look at lots of doors and think about what makes some look right and some look wrong for you.
Google image search is an easy first step.
In my opinion, the most important points are
- that stiles and rails should not be skinny - as they are in the very cheapest furniture -
- the top rail should be the same breadth as the stiles
- the bottom and centre rails should be broader - up to about twice the breadth.
But so much of this depends on the look of the whole thing that it's futile to generalise too much. What works on a single door would look wrong on a run of six tall thin ones. The presence of mouldings on the edges of stiles and rails changes the proportions hugely.
You could do worse than make up some dummy doors in thick cardboard and stand them in place for a while to look at them 'live'.
I've no experience of this whatsoever but someone on here asked a similiar question about proportions a while ago. Some people said they used Fibonacci numbers when trying to make multiple dimensions look right.
Hope that helps.
Hi - I must admit I have just this week completed a new paneled front door, and when at the drawing stages I too was perplexed about the ratios and proportions and read up about the Golden Ratio, browsed door manufacturers websites etc and ended up ignoring all and building what looked on paper 'right'.
Below is what I ended up with - literally just hung with only one coat of varnish on the frame, to my eyes it looks ok, but I guess others may beg to differ :wink:
If I were you I'd take AndyT's advice and copy one that you like!
Ed
Looks fine to me.
Very nice door.
I do exactly the same - go for what looks right, never mind the rules.
......... after all, if it looks wrong, it is wrong and it will remind you of the fact every time that you clap eyes on it. Whereas good proportions just blend in nicely.
All best.
Thank you for looking guys I think I'll take your advice and mock several different ones
up out of 6mm mdf till THE look arrives
