We moved house a little while ago, and my partner decided that she liked the look of those radiator-cover things she saw in a couple of the houses we looked at. I told her that if she wanted them, she had to let me make them, so at least they're not so ugly as some of the things you see lining the shelves of B&Q, Homebase et al..
Problem is, I don't much like the idea of making them entirely out of MDF if I can help it, but I'm a little worried about expansion, which I think I understand in basic principle, but don't totally trust myself on! Would being stuck over the top of a radiator exacerbate any problem with expansion? I imagine it probably keeps moisture away, but at the same time the thing will heat up and cool down significantly more than once a day... do people use MDF for these because it's more dimensionally stable, or just because it's relatively cheap?
The other thing I'm not so sure about is that one of our radiators is in the lounge, directly underneath a low-hanging curtain which dangles about 10cm/4" below the top of the radiator. On one hand, I quite like the idea of having a cover on this one 'cause I can taper the ends back to the wall to stop the curtains catching on the rad (the previous occupants had installed a cable-operated curtain-drawing system), but on the other hand they have to trap a lot of heat behind them! I was thinking of lowering the front slots on the cover to come out below the level of the curtains, and folding the internal reflective sheet over the top of the rad inside to try and direct the hot air out the front. Does anyone have any idea how likely this is to help, or whether it's a bad idea after all?
