Dusty
Evening all , I have a couple of questions for the wise and hoped you may be able to help .
1 ) I have to make some laminated curved sections , similar to the radius of a railway carriage roof . It will be made up of 4 to 5 sections and I am looking for a glue preferably PVA of some nature with a decent open time as I will be working this solo so need the time to glue up and clamp myself , total curing time is not important as I only have 5 to make and several weeks to do this in so can remain clamped for days if needed . Have thought about cascamite but I can be dealing with the sticky mess everywhere as I work .
2 ) I have just splashed out on a new toy , spindle moulder , which will be arriving on monday , I have spent to long struggling with a router table setup for bigger stuff . Ant way , I need to make so 42 x 12 mm rebates , 12mm being the depth of the cut as I am using a 50mm block , It is soft wood so not massively dense , would "you make a 12mm cut in one or two goes .
3 ) I am currently about to start a long run of windows and I am in need of painting them pre fitting , primer and undercoat and topcoat , ideally looking for someone to spray them as to be honest , all the decorators around me are either ruff as a nuns #### or to busy . I am based in south somerset , so preferably looking for some one local , would anyone here be interested or can recommmend someone , I have found a sprayer near-ish but have no personal recommendations .
Thanks for any help in advance
cheers Sam
cheers Sam
