Mister S
I'm thinking of getting a Morris Minor Traveller and I've been doing some research. They look great, but I'm wary of the effect that the Great British climate has on the exposed ash woodwork. The woodwork is structural and has to be in good condition - it's part of the MOT.
The owners club recommends rubbing down and re-varnishing every year, preferably with a micro-porous varnish. They also suggest possibly using micro-porous varnish on the interior and non-porous on the exterior. The reasoning is that most water is kept out of the joints / wood, but if any does get in, it can dry out into the interior of the car. This might work, but that is a lot of rubbing down and varnishing :shock: . It also means rubbing down the wood which is right next to the paintwork - not for the fainthearted!
The largest specialist/dealer in the UK recommends (and they use) danish/teak oil only, with annual applications. They think that you can't stop water getting into the exposed joints (and there are a lot of them!) and varnish traps the water in the wood and makes it rot faster.
But is danish oil suitable for external use?
Steve
Steve
