woodfarmer
You probably know when I started to take up turning I had this idea to turn monster bowls, fortunately I chose a lathe that is versatile.
Last week after reading here I decided at having a go at spindle turning. What prompted me was the desire to make a teether/toy for my grandchild. As is obvious I had no idea how to do it so just went ahead solving the problems my limited experience caused as they arose.
Starting with a 100mmx100mm square x300mm long pear log I turned it between centres and marked by eye where I wanted the "globes".
Here is the spindle with the two approximate globes.
now to make a ring, for this I needed to construct a Heath Robinson jig to hold it. This forced me to go outboard as I did not have enough swing over the normal bed. Note the counterbalance on the right screwed to the original jig.
Now I have a little bowl on a handle, maybe a spoon or a pipe
Turn it over in the jig and do the other side.
part off the ends.
now ready for hand finishing.
I hope you enjoy this.. I suspect there is a much easier way
part off the ends.
