Hi Everyone, I'm new to the forum - not a complete novice but it's about 40 years since I did any turning and so I'm a little rusty !
So ... I've bought this lovely little Myford ML8 - it's a fairly late (by Myford standards !) model in silver Hammerite - serial number N145679 I think - must be about the last of the silver ones ? 36" between centres, bowl turning rest on the outboard side, complete with a reasonable set of Sorby and Marples chisels and gouges and a "6 in 1" Universal chuck made by Hattersley & Davidson (they bought Sorby and are now part of Eclipse/Spear&Jackosn etc.).
It has a second set of radiused tool rests as recommended (and custom made) by the late Keith Rowley and the wooden stand is almost identical to the design in his excellent book. The lathe was pretty mucky and covered in a layer of wood dust and sanding sealer but I've stripped it all down, cleaned it off and underneath all the gunk it was in brilliant condition. No play whatsoever in the bearings or anywhere else for that matter, I had to rewire the electrics as the perished rubber clad cable was a bit of a health hazard but all in all for £150 I'm really pleased with my purchase. It came with an assortment of face plates as well as the universal chuck and has clearly only been lightly used for bowl turning - I don't think the tailstock has ever been moved from the end of the bed as it's like new. I've beefed up the stand a little, mounted the lathe on 6mm rubber pads and it runs like a dream - no vibration at all and virtually silent running - for a lathe that's got to be at least 25 years old pretty remarkable.
It was a bit odd when I got it as everything had been set up back to front, headstock on the right, tailstock on the left .... even the switch had been wired so that the motor ran backwards ... I can only assume it was someone who was left handed that couldn't live with the perversity of everything being the other way round ? I can't think of any other reason but I'm open to suggestions ! It's all back the 'right' way round now and the switch rewired for correct motor rotation ... it was lots of fun redrilling and cutting the 2" thick oak plank it sits on. So, I'm nearly there and very happy .....
But ... there are no centres at all with the lathe.
I'm not sure what I'm going to be doing with it but, initially, I just want to get back into the swing of turning and some spindle turning looks on the cards to get my hand back in. I've done a fair bit of reading lately and I reckon that a live centre on the tailstock is a good idea but should I be looking at a 2 prong or 4 prong at the headstock - and indeed what size would be a good general use one ? Budget is a bit tight so I can't get a full set and need to be a bit sensible - so any suggestions as to an intermediate quality make/supplier would help. It's an MT1 Taper on both ends.
Many thanks. Phil
PS: (hammer) After checking the bearings on the headstock shaft I went to refil the bearing cases with oil as per the instructions "Fill until oil flows out" and had a real freaky moment when I ran it up to find the ATF (found the recommendation in this forum for this cost effective alternative to Myfords hugely expensive stuff) started to pee out of the bottom of the bearing shaft !! So.... back to the forum only to find that this is actually what should happen ! #-o Seems a bit dopey to me - putting oil in the top and then mopping it up as it comes out the bottom ! So - the only other question I've got for any Myford geeks out there is - how often to I have to refil the oil and watch it pour out and could I put less in than the 60ml recommended to save the clean up ?
Many thanks for a brilliant forum - hopefully there will be a few Myford enthusiats still going strong - or am I the one to switch the lights off and close the door ?
Many thanks. Phil
