bogmonster
Not in a rush but started thinking about upgrading my lathe, a Poole Wood 28-40. Money is tight as I work part time due to ill health and a long way from retirement. Anyway, thinking about what options are out there. I mainly turn bowls and sometimes quite large ones. I have turned some hoofers on the Poole Wood, probably far bigger than sensible for the machine. I have a custom large bowl attachment that allows me to swivel the headstock and work without leaning over the bed. This arrangement works well for me and don't want to lean over a bed. I fancy the idea of a large chunk of cast iron and while a Wadkin RS appeals the turning position does not. Many of the older lathes have outboard turning but I don't think I could manage with the bowl turning in the opposite direction. I could have a reversible motor but then there is the issue with the chuck and faceplates unscrewing and messing with grub screws on all of them sounds a faff. I would like variable speed as well. I must be able to easily fit a scroll chuck - preferably one that uses the Axminster jaw system as I am already invested in that direction. Also I want something I can maintain easily and if needs be get spares for. The Poole Wood has a 6 pole 1HP motor and that struggles on big bowls - well, medium sized ones as well, so I find myself needing to back off when roughing out. So what are the options....
EDIT - I also want a hollow headstock shaft so I can use a vacuum chuck easily - kind of view a vacuum chuck as vital equipment now....
Record Maxi 1
Jet 1642
Jet 3520B
Short bed graduate (or similar, maybe Viceroy) with inverter.
I know all the above are totally different beasts but all might meet my needs. Of the above I actually fancy the idea of the graduate. Prices need not be too spendy and they hold value well. My issue is not really cash flow. I know it would be too low for me but blocking it up would be easy I would think. Capacity is a bit limited - 18 inches I think. I do now have a bandsaw so at least I can get a round to start with whereas up to now I needed additional capacity for odd shape lumps of tree. Is a Graduate going to be up to the task of an 18 inch by 9 inch bowl or am I asking too much of it? What size motor can be shoe horned into that pedestal?
The thing that puts me off the Graduate is that I do the odd hollow form and have a hollowing jig - not really sure that can work on a short bed lathe without some seriously hokey arrangement.
Any other ideas I can put into the melting pot?
BM.
Record Maxi 1
Jet 1642
Jet 3520B
BM.
