mac1012
Hi I think the link and bearing part may be in need of replacement but want to check first with other hegner owners
its a bit of a knocking sound really that gets worse when the machine is warm after a couple of hours running yesterday I took the cover of and had a look at the link , when the link is at its most vertical position and I wiggle the top arm up and down a bit there is some play between the bearing and the plastic housing it sits in that is visible , what puzzles me it is not between the bearing and the alan bolt but around the pressed in bearing and the plasic it sits in which dosent really rotate when the arms are turning around if you get my drift
when I turn the machine of and the motor isn't running but the arms are still turning you can hear a visible knocking coming from the link area the bolt is tight and all washers are correct
the blade and cutting is working fine although on heavier cuts the machine does seem to pulse but I think t5hat may be my mind and ears playing tricks on me (hammer)
but I guess it could wear after time ? so want to check whats normal and what isn't
also when the machine is on it kind of pulses think of like a regular heart bit like a droning sound , I don't know if that's just normal or not
I will try and post a video later when the machine has been running a couple of hours
I have got some orders I need to finish this weekend but then I am going to try and get to the root of the problem
mark
mark
