I wanted to ask those that know better, if my proposed construction method for some ply boxes is reasonable.
I plan to make a few different pieces of furniture around this basic box, either by adding shelves and/or doors, so this is just the basic carcass.
It would be 800 x 800 x 400 mm, from 24 mm thick ply. The back panel would be 15 or 18 mm thick ply with 3 pocket holes per side. Each corner has a glued rabbet joint, relatively thin on one side ~5mm. I hope that makes sense.
I plan to add some feet to the base too, but haven't decided how to tackle that yet.
I guess in theory I could route a rabbet for a back panel instead of pocket holes, but I am trying to avoid buying a router for the minute.
Does this look viable?
