Plumbing......
kostello
11 Feb 2011
slightly more sunny flackwell heath
I think I've got a leak in the coil of my hot water tank.
So this afternoon I've disconnected the coil from the heating system, capped it and pressure tested it.
In 3 hours the gauge has dropped from 40 psi to 34 psi and is still dropping.
Am I right to think it's knackered?
sasha
When you say disconnected it - I assume you've disconnected both ends of they as the enter\exit the tank, etc.?
In which a pressure loss would mean knackered tank to me.
HIH
Dibs
You could always un-cap both ends & put a tub/bucket under the bottom tapping of the coil, if it fills with water you have a leaky coil.
They usually go with a pin hole forming in the coil & the give away signs are that the central heating header tank starts over flowing as the bigger domestic hot water header tank is usually higher & the water is trying to find its own level.
HTH.
Cheers.
Edit, depending on how you`ve capped the ends you could be getting a pressure drop as some plumbing fittings aren`t air tight
Also your coil is full of air surrounded by a water jacket and the water temperature could be falling during your test?
pressure is proportional to absolute temperature (kelvin)
Bob
