Afternoon,
I've recently bought a Sedgwick MR planer. It's one of the older ones in the two tone green and 1500mm beds. I seem to be having problems squaring timber.
I've set my straightedge along the beds and made some small adjustments to get the in feed and out feed in the same plane. I've set the blades to the required 5mm drag on a stick, squared the fence and had a go. All seems good until I use the thicknesser, where the timber appears to be coming out slightly wedge shaped across the width. I've checked the blades and they seem to be good and parallel with the table. Is there something I'm missing in the set up? Or could the thicknesser bed be out relative to the cutter block / blades.
Any help greatly appreciated.
Euan
Euan
