Aggrajag
I'm sure it's been asked before but I can't find it despite repeated searches both here and via Google.
I use a fair bit of untreated pine for scrollsawing, mainly because I've got access to loads of old pallets. I enjoy making ornaments and trinkets so I've cut loads of the stuff but I've never really concentrated on finishing anything because I've been put off from past failures. The problem I encounter, is that whenever I've applied anything the inside cuts swell up and go fuzzy / furry, which means I then have to carefully sand the entire thing again, inside and out, almost making the original cutting futile. (I guess this is an issue with all softwoods?)
I've bought sealant, wax, oils and sprays but after a few failures never got around to testing multiple scenarios to see which is easiest and most effective.
Can some expert please point me in the correct direction - what's the easiest way to make a pine ornament presentable?
Thank you.
Thank you.
