That's good to hear as I didn't really want to fork out for hardwood to do them.thetyreman":3kjj66b5 said:well I modified my cheapo clamps, it made a big difference, not only strength but also sounds better, they used to ring and sound horrible, you can buy pine for next to nothing, I used 2 x 1 PAR Redwood Pine just made them all to fit each one individually, only an afternoons work to do all 12 clamps. I think using hardwood for something like this is a false economy, not worth the extra cost imo
That's a great video, just what I needed.Trevanion":hzh33hpl said:I remember seeing this video from Paul Sellers on the exact same topic:
[youtube]AyKiGmRq3wY[/youtube]
He's got some great tips there, especially waxing the bar for a slick adjustment, I wax my flat bar sash clamps and it makes a hell of a difference especially when you're doing a time-constrained glue up and the heads are jamming up constantly. For the most part, I use Record indestructible T-Bar clamps so not many problemsJust remember these Aluminium clamps aren't meant for tightening until you physically can't no more like you can on a Record, I've seen several where the aluminium bites in the bar have torn out from over-tightening.
thetyreman":2zs4tysr said:well I modified my cheapo clamps, it made a big difference, not only strength but also sounds better, they used to ring and sound horrible, you can buy pine for next to nothing, I used 2 x 1 PAR Redwood Pine just made them all to fit each one individually, only an afternoons work to do all 12 clamps. I think using hardwood for something like this is a false economy, not worth the extra cost imo
I would suggest that he tries both, first try them hollow and he can come to his own conclusion.powertools":fne1e3sw said:thetyreman":fne1e3sw said:well I modified my cheapo clamps, it made a big difference, not only strength but also sounds better, they used to ring and sound horrible, you can buy pine for next to nothing, I used 2 x 1 PAR Redwood Pine just made them all to fit each one individually, only an afternoons work to do all 12 clamps. I think using hardwood for something like this is a false economy, not worth the extra cost imo
Well I am happy to be corrected.
I thought that the op wanted to make his clamps more heavy duty and didn't realise that noise was the issue.
I have never had a problem with the bar bending but if you overload this type of clamp the tooth on the adjustable head will tear into the ally body therefore no matter what you do there comes a point that you will not be able to increase the clamping pressure.
For me the fact that they are light weight and quick to adjust is their big advantage on simple glue ups.
