two lttle crafters
Hi
I need to drill a large quantity of 25mm diameter holes into softwood (pine) to a depth of 20mm. The holes need to be reasonably accurate. But not perfect.
1st option.
I was l;ooking at pillar drils, there are load to pick from but what size do you need before it would have enough tourqe to drill the holes with a flat bit or forstner bit.
2nd Option
I have looked at drill stands, again they are plenty to pick from, My own power drill is reasonably power full and can drill 25mm holes with ease. Just not sure how good it would be once attached to a clamping device or how good are they.
Like everything else in life I do know you only get what you pay for and a £600 floor standing press drill is the answer, and my budget is more limited than than space.
So needs to be something along the lines of a bench mounted drill and as cheap as chips.
Is there and benefit to be gained by using a particular tye of drill bit? is a Forsner bit more or less demanding on a machine.
1st option.
2nd Option
