suprasport
My new Perform ccbb arrived today and i can honestly say i have never spent so long setting anything up in my life. The stand was a nightmare and in the end i put it on a cupboard made of 18mm mdf with 2 layers on top and on castors.
i have been reading up on how to tension and set it all up, and it ain't easy, every time i went to set the bearing guides i would get it just the right distance and then start to to tighten the nut with the allen key and the grub screw would nudge the bearing over, then i found if i had the bearing touching the blade and then tightened it up it got nudged over just the right amount
Oh! and it had had a bang on the top casing,a scratch and a very very small dint but it had been very poorly painted over by a 2 year old with some tipex. rang them and they gave me a £5 voucher.
So first impressions was what a load of junk. :evil:
Then i would find that the back bearing when set at the lowest point (guide near the table) then lifted to its highest setting there would be a difference of 3-4mm ie. the bearing guide wasn't running parallel to the bade.
The blade has been wandering all over the place yet when i attempted a 1.5mm veneer off of some 6" oak it was damn near perfect :?
So it has been bugging me and i have just been out to get it sorted and found out that it has a hidden feature Axminster don't tell you about,
yes it has a tensioning gauge :shock: I was messing about with it when i noticed the upper casing was twisted, and at first i thought this was due to the bang it had received, so was gutted thinking it has got to be sent back and i have to start all over again. However after further messing i discovered that if i released the tension on the blade the casing came true again. So i set the tension by watching the casing and using the door pushed to in order to check it, then set up the bearing guides again and hey presto it is working like a dream :lol: after a bit of practice with the feed rate and a new dure-edge blade i think i will be onto a winner.
Now the lathe is coming tomorrow cant imagine and hoping that takes no setting up :lol:
