Pen Turning - Where to start...
Lee J
20 Nov 2008
After doing my second successful local craft fair on Saturday I was analyzing my sales, working out what sold the best and making a plan as to what stock I will make for my next one in the spring. I had made a couple of notes of some ideas people had suggested to me and a fair few people had asked me if I made pens. With it being a Xmas fair it seems a few people would of purchased hand made pens as gifts. So I thought I'd try my hand at pen making. However I'm completely in the dark about pen turning/making. So this morning I will dedicate to researching what is needed and involved. I don't want it to take over my craft stall, I just want to include maybe a dozen hand made pens. So the first port of call is you knowledgeable folk on here.
What equipment do I need? Is there a special small lathe available or maybe an attachment for my big lathe? I have a Record Coronet lathe that to me would seem far too big to make a delicate pen on?
What other gadgets would help? I think I've seen something somewhere that helps with the assembly of the pen? have I dream't that?
Any help would be gratefully received
theartfulbodger
2 Nov 2010
Midsomer County, Englandshire
Lee J
20 Nov 2008
thanks for that. So I could use my coronet lathe, it's the mandrel that seems to be the important bit
WoodMangler
7 Oct 2011
Mid-west Wales
It's much easier to make small things on a big lathe than it is to make big things on a small lathe...
xy mosian
21 Feb 2009
West Yorkshire
Interestingly my neighbour is just beginning to turn pens. My help has been sort as he is no woodworker. A couple of points have come up:-
The drilling of the blank for the, in this case brass inner barrel, requires the drill bit to travel about 70 mm. His table top machine cannot do this, awkward.
The jig we have produced to hold the blanks for drilling works suprisingly well. Two blocks of 3" X 2" dowelled together with a hole, slightly smaller than the diagonal of the blank, drilled vertically through the joint. The blank is inserted, a quick clamp applied and there is the blank held square to the drilling machine table.
Have fun, ahve a look on the Turning section there are sure to be others doing t his.
xy
Lee J
20 Nov 2008
JPT - that link to woodturned.co.uk is fantastic. thanks for that
Lee J
20 Nov 2008
what MT is my lathe likely to be then? It's a full size lathe, Record Coronet size 0
Dieseldog
13 Mar 2011
Padstow North Cornwall
A smaller tool rest will help
decent glue for the brass tubes something like Araldite
sharp tools is a must
a decent pen blank jig
if your going to be turning Acrylic pens when drilling the 7mm hole take your time and remove any waste from your drill bit or you will blow the Acrylic blank
post a pic up of your first pen when you make one
hope this helps
jumps
29 Nov 2010
kent
1MT (both spindle and tailstock)
russell1
New member
24 Jan 2011
Thick Superglue from http://www.starloc.eu/ who are located in Runcorn (UK) Cheapest around for price and quality.
Pen Kits from www.timberbits .com fabulous prices and great servive, David is based in Sydney Austrailia but again price and service are great. Also some videos and lots of instructions.
Planet Tools do a starter kit with Mandrel and blank end cleaner. See last 2 items on this URL
http://www.charnwood.net/shop/category/ ... ning-tools
Have fun
Russell
