milkman
Hi all,
Bit of advice needed. Been asked to box in a boiler in an alcove in the style of some existing joinery. They want it to match a built-in that’s already there, it has ogee mouldings. Not sure if you can buy this as applied beading so was going to rout it.
Can you use the combination panel door router bits such as this one on full height wardrobe doors? Would the glued area be strong enough?
Am thinking 530mm x 2000mm 18mm MRDF panelled door. I'm very limited on being able to mill timber so I was going down the MDF route.
Or should I be thinking real wood for something like this?
Ideas appreciated
Marko
Ideas appreciated
Marko
