One mobile base for both thicknesser (Jet) and Jointer (Sip)
lastminute
26 Apr 2009
West Yorkshire
...has anyone built a mobile unit housing the above...I assume the thicknesser would be on the bottom with the jointer sat above!
Both are seperate at the moment...any ideas welcome.
Gerry
flh801978
21 Dec 2008
Sheffield uk
I did a crude mobile bench just 25mm ply on casters and legs supporting a top of 25mm mrmdf placed my old planer on top which was great but my thicknesser was a pain to use being down below....so i was contstantly swaping them over..
Ian
bought a startrite planer/thicknesser as a way out
fluffflinger
21 Oct 2009
Northampton
I am definitely going to do this myself and had considered (because I wanted both machines at a pleasant working height) attaching them to the opposite faces of the same base and then by some cunning method have this base swivel and then lock into position.
My back is rubbish and I just couldn't get my head around having the bed of the thicknesser operating at about 300-400mm off the ground. I have a DW733 and a no name table top planer (which for all it's failings does a lovely job). Workshop is small so I have always wanted these bits of kit on a single mobile base stored under a bench. I wanted to combine easy of storage with ease of use.
My idea for the swivel and locking device was to build a rigid torsion box base, run a steel bar through the center (made easy by the fact that I can drill the webs of the torsion box and then after it's finished pass the bar through it) and have this shaft run in a couple of bushes mounted on the frame of the mobile base. Locking would be by a couple of bolts passing from the frame of the base into the sides of the torsion box and screwing into a couple of imbedded nuts. I appreciate these machines are quite heavy and I might have issues rotating them so the base of my mobile base I was going to create a void and put a couple of council paving slabs in the bottom. Would also solve the problem of the two large council slabs that have been sitting outside my shop for two years!
The only concern I have is that it will make using one after the other a time consuming task, that being dependent on quickly and simply it can be unlocked swivelled and locked again. Greater minds than I will doubtless find another 10 reasons why my scheme is fatally flawed.
If I could do more than just spell Sketchup and actually use it, all would be much clearer but all I have is a scribbled drawing on a piece of paper and dreamy doodles in my mind.
I'll now sit back and await gallons of scorn to be poured on me from a great height or should I just call the asylum directly?
doorframe
22 Dec 2010
Essex
No scorn here, though I do have the number of the local Institute for the Woody Impaired.
I had a very similar cunning plan for my SCMS and RAS (didn't happen, but who knows about the future). Stability wouldn't have been an issue as it would have been fixed to the wall and floor. I say go for it. I assume you want it mobile, so good casters and a smooth floor are a must, as the total combined weight will be fairly considerable.
Make sure you do a WIP.
Roy
fluffflinger
21 Oct 2009
Northampton
Well if you find that mag Tinbasher I'd certainly be interested and thanks for your vote of support Roy WIP it will be I promise.
lastminute
26 Apr 2009
West Yorkshire
Thanks for the video Richard, it works well and balances nicely with both machines roughly about the same weight and mass!
However my jointer is solid cast iron albeit only a 6" model and would probably not work as neatly as this one, plus the table length is approx 29" so would take up too much room and be far too heavy and dangerous to balance.
I have my jointer on a trolley now, stowed under a bench below my lathe and my thicknesser on a trolley at a nice height which is mobile enough to move anywhere I want.
So hopefully my problem is solved for the moment.
