Hi,
Does anyone know where I can get some Olson crown tooth scroll saw blades? been reading a scrollsaw book and they recommended them for sawing Corian, the Skip Tooth Pegas blades are ok but if there's a better blade available then I'd like to give them a try and see if they are any good.
Today I was cutting some Corian that was 20mm thick and the Pegas number 3 easily managed it including some very tight turns..... as usual I hold the material with my trusty Mole Grips to saw and they grip the Corian well and no chatter, the Corian is mega sharp when you cut it so you need to be careful handling it as the cuts are like paper cuts and we all know how painful they can be :shock: I finish my cut Corian bits using my Sand-Flee mop that not only takes the sharp edges away but gives it a lovely soft sheen finish...... you can polish it further using T-Cut and even Brasso polish works well on dark colours but if you are polishing white Corian you need a clear polish (I used 1000 grit wet and dry and then use car interior polish to finish and comes out lovely.
Will post some pictures of my experiments soon
Brian
Brian
