Fromey
After a bit of use, oil stones get, well, oily and black with swarf. Do you;
Ignore this and just load on more oil letting the gungy bits eventually dribble off down the side? (Oooo Matron!)
Wipe the stone clean after you've finished using it?
Wipe the stone clean regularly during use and recharge it with fresh oil?
Furthermore, what do you wipe your stones down with? (i.e., is there something that will minimise leaving fragments of itself behind on the stone (e.g., wiping down with paper towel leaves a mess)).
Lastly, do you store your oil stones 'dry' or do you give them a coating of fresh oil?
Thanks, as always, in advance.
