Could someone please help me out with this?
I recently received a Numatic NVD750 from Axminster.
Im confused as how to use this vac with the Numatic disposable bag for fine dust removal (sanding etc.).
The instructions show to connect the 32mm hose via the 100mm to 51mm reducer to the 100mm inlet, and fit the disposable dust bag to the hose flange inside the drum?
http://www.axminster.co.uk/media/downlo ... manual.pdf
The Axminster website shows a photo of the 32mm hose connected to the other inlet when using a sander?
http://www.axminster.co.uk/numatic-nvd7 ... -extractor
When I did it that way (as in photograph) after about 10-15 minutes the vac got hot to touch. :shock:
But I thought this was the right way to do it as the dust should be going from the hose straight through the inlet and into the disposable dust bag?
Can anyone shed any light on this please?
