I use Freud blades in both my saws, but I have had problems with the blade on my mitre saw. It's a 305mm 96T blade. I have two of them. The first one whilst using, there was an almighty bang. I had no idea what happened. Had a look at the blade and saw, everything looked OK. Next cut, the finish was rubbish. On closer inspection, the blade had suffered a bent tooth, but I couldn't figure out what caused it. I really liked the blade. It cuts extremely well with a beautiful finish, so I got another. Lo and behold the same thing happened a couple of weeks later, but this time, I realised what had happened. I was cutting the end from a fairly small bit of wood and the off-cut, fell back into the blade, exploding with a mighty bang, bending a tooth. The solution is to keep the saw lowered until it stops. Which isn't such a hassle. I removed the bent teeth on both blades, ground them back to the blade thickness and they both work perfectly well. Finish is just as good as before and balance is fine. I complained to Freud, but they didn't bother to respond past the first reply. That really annoys me, when companies don't care!
I had a good look at the CMT blades, they look good and appear to be cheaper than Freud, so I will give them a try next blade. They give lots of scientific/technical information about their blades and teeth and I'm easily impressed with technical stuff, lol
