mailee
Just having a rant here really so forgive me. I have been fitting some wortops today and it has taken all day to cut one joint and two cutouts. I did have to remove the old worktops and fit a couple of flexys to the pipes. But even so if it hadn't been for the walls being so far out of whack I would have got on much better. I have had to scribe both worktops into the walls and cut the joint for an out of square corner. The walls looked like a donkeys hind leg and the house is a new build! I should have known it was going to be one of those days when I cut the first joint wrong! I cut the female joint at 600mm and the tops were actually 616mm Luckily I spotted my mistake before cutting the other one but it did mean I had to shorted the top a little. Again this was lucky it was an end run so there was enough to play with. Anyway I am back there tomorrow to fit the other side and a breakfast bar so hopefully a new day should be better. I think I may have to make the splashbacks out of rubber though to fit the walls! Thanks for listening to my rantings guys, at least I have got it off my chest and it does help.
