Looking through my pile of collected/inherited/found stones, I found one that looked as if it might be interesting under all the grime.
I spent a while wiping it over with white spirit to find a very nice, little used, labelled, Norton India Oilstone, marked Fine No 0.
Now, I like to use water with a splash of detergent for sharpening but this is an oilstone, and has clearly had some little use as such - it is very oily in the pores.
Three questions:
First of all, what would be the approximate grit size of this stone? It's clearly fine, and produces a nice edge.
Secondly, can I now use water with this stone or have I to continue to use oil? I did give it a try with water and apart from the oiliness it seemed to work well enough.
and finally, even if I CAN use water, what would be the best for the stone in regard to its effectiveness, rate of wear, etc? Would it, overall, be better for the stone and for my sharpening to use oil with it?
Martin.
Three questions:
Martin.
