Nice security solution
knappers
19 Apr 2010
Leicester
I had been looking at mechanical keypad entry systems to fit to a door. Due to the door frame being aluminium with adjoining wire glass, I wanted something to integrate with the existing Euro sash lock. All the add-on key pads I could find needed a bottom fixing hole beneath the follower, but I couldn't find a replacement sash lock with a hole and 48mm centres.
Then I found this... (by the way, I was not responsible for the original sash lock fitting mess...)
Just the job. Easy to fit, easy to use, unobtrusive and has different entry and locking modes. Very happy camper.
Si
Is the handle held on with bolt through fixings? If not, couldn't somebody just unscrew the rose, and turn the follower with a screwdriver?
